Where are Thingworx Entities physically stored?
I am trying to revert the Thingworx instance to OOTB installation. Is there any existing way to do this?
 Can we do it by replacing all the metadata files and db with OOTB snapshot.
Hi @ajaysingh are you referring to the revert from the DB ?
ajaysingh1-VisitorAuthor
yes if it feasible
In such a scenario I suppose you'll need to roll back on the DB directly. Which database are you working with?
From the composer side, are you periodically performing full backups (Export) ?
