Where can i find the right Thingworx Flow installation document?
I have the same issue, it is related to manufacturing apps and more precisly this issue comes up when missing to do Post instalation steps, so any idea how can resolve it please?
Hello Slangley,
I could not wait until find the root cause and fix it, so i uninstalled and reinstalled Thingworx along with Manufacturing apps.
I am sure that issue came up because i miss to do the post installation of Manufacturing apps. so the solution in my opinion is that should find way to do those steps of post installation through the configurations files.
Support
May 11, 2021
Hi @YD_9850038.
Please clarify the exact issue.  Are you saying that you're unable to install Flow and Manufacturing Apps on the same instance? What versions of the product are you attempting to install?  What installation method are you using?  In what order did you install Flow vs. Manufacturing Apps?
--Sharon
The issue does not have anything to do with ThingWorx Flow, the issue i have reports the same error and behaviour as the one related to ThingWorx Flow, but here i installed Manufacturing Apps and tested it, it was working fine but after retarting tomcat, thingworx fails to start with error ;
rg.postgresql.util.PSQLException: FATAL: la autentificación password falló para el usuario «twadmin» (pgjdbc: autodetected server-encoding to be ISO-8859-1, if the message is not readable, please check database logs and/or host, port, dbname, user, password, pg_hba.conf)
2021-05-11 17:29:00.055+0200 [L: ERROR] [O: c.t.s.s.e.EventInstance] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-11] Error Executing Event Handler 'RunScheduler' for event Type.Thing:Entity.PTC.SCA.SCO.KPIScheduler:Event.ScheduledEvent
Support
May 12, 2021
Hi @YD_9850038.
The error indicates your twadmin password is incorrect.  Check the platform-settings.json located in \ThingworxPlatform.
If you still have issues, please provide the versions of ThingWorx and ThingWorx Manufacturing Apps you are installing.  It would also be helpful for you to provide the ThingWorx logs located at \ThingworxStorage\logs and Tomcat logs located at <tomcat_home>\logs.
--Sharon
