Jul 30, 2024 5:10 PM UTC
Where to find installer logs?
Hello
My thingworx installer is failing at the last step while waiting to connect thingworx and whenever it fails the folder structure is rolled back. I am trying to locate the errors but as soon as installer stop it delete all the folders .
Is there any specific location i can look for installer logs?
Jul 30, 2024 5:18 PM UTC
Hello @unknown ,
Generally ThigWorx locations are present at these locations:
  • <Install Location>\installer\logs\foundation-<date time>.log
  • <Install Location>\installer\foundation\local-mode-cache/cache/chef-stacktrace.out
  • <User Directory>\AppData\Local\Temp\bitrock_installer.log
Kindly revert back if issue is still present or you are not able to locate the logs.
Hope it helps.
Bhawna
Hello @unknown ,
Hope it helps.
Bhawna
