Which widget or extension is used for Time Slot,Share Report,Edit,Update and Delete in grid widget
I have to create this kind of screen in below attach but that widget is not available in ThingWorx Platform I'm new in this platform, can you please help me which widget or which extension  is used for Time slot,Share Report and For Edit,Update and Delete in grid Advanced widget.
Thank in advance
Riya Gajbe
slangleyAnswer
Support
Hi @VikasGadpayle.
This doesn't appear to be just a single widget, but a mix of the Date Time Picker, grid widget, or possibly others.
We recommend you review our training guides available on the Dev Portal.  This would be a good starting point.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @VikasGadpayle.
--Sharon
Can you have specific Widget or extension name for share Report, Time slot or  Edit, View, Delete in  Thingworx
This helps a lot.
Support
Hi @VikasGadpayle.
As previously stated, it doesn't appear there is one single widget for providing the functionality you need.  But perhaps we're not understanding.  What is your use case that you would restrict you to the use of only 1 widget?
--Sharon
