pshashipreetham
White Border on the Button
Thingworx Version: 9.3
When ever the Mashup is opened as PopUp on a button click, there is white border on the button (button on the opened Mashup).
Shashi
PEHOWEAnswer
Hello @pshashipreetham
I believe the issue you are seeing is the focus. Have you reviewed  Article - CS324593 - ThingwWorx Web Components customization with Visual SDK CSS
You will find the following section:
  • Remove Focus box from UI items
ptcs-focus-overlay {
  visibility: hidden;
.ptcs-wrapper:not([no-wc-style]):focus:not(.dummy):not(.dummy):not(.dummy) {
    box-shadow: none;
Hope that helps.
Peter
PEHOWE17-PeridotAnswer
  visibility: hidden;
    box-shadow: none;
Hope that helps.
Peter
pshashipreetham
Hey Hi @PEHOWE,
Is there a way to write a CUSTOM CSS for a ptcs-button when it is disabled? When the button is disabled, its background color should be none or something like that. I was not able to find or code the proper CSS for it. Can you please help me out over here?
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Hello @pshashipreetham,
I am not sure I understand your question. The Style Theme being used has a definition for disabled buttons.
Can you provide more information on your goal.
