Why i can't see Datafilter widget in TWX 9.1 ? Can I achieve it by creating service ?
Hi ,
I am using TWX 9.1 version , unable to see Datafilter widget in widget panel . what is the replacement for this widget?
slangleyAnswer
Support
Hi @VS_9760165.
Take a look at this page from the Help Center.  Notice there is a video available that may answer your questions.
--Sharon
@VS_9760165
Thanks for opening this post o community. You can check the Advance Data filter widget present in 9.1 contains some extra functionality.
If your use case does not permit that you can use legacy data filter by selecting widget category to all. Check and let me know if it works.
Mohit
Hi @mgoel
I see that i have Chip based data filter widget , but how to use it ?  to filter do we need custom service?
slangleyCommunity ManagerAnswer
Support
Hi @VS_9760165.
--Sharon
