11-Garnet
Widget Development - Resolve Binding in Design Time
I would like to access the data from the infotable bound to my widget during design time (ide).
Are there any JS functions I can use? I saw there are some observers on the 'isBindingTarget':true properties but really would be thankful for some pointer in the right direction.
There are two key methods you could look into:
  • afterAddBindingSource is a method that you can implement in your widget object. It will be invoked by the platform whenever a binding source is added to any of your widget's infotable properties.
this.afterAddBindingSource = function (bindingInfo) {
 const propertyName = bindingInfo.targetProperty;
  • getInfotableMetadataForProperty is a method that is available as part of the widget API that you can invoke to retrieve the data shape fields of any infotable property that has an active binding. This is something you can invoke from afterAddBindingSource, but also at any other point in your IDE object:
     const dataShape = this.getInfotableMetadataForProperty(propertyName);
Hope this helps.
Hope this helps.
gbirnzain11-GarnetAuthor
11-Garnet
This is exactly what I was looking for.
Thanks!
