Nov 24, 2016 9:16 AM UTC
widget for 3d coordinates input
There is a property base type which is vec2, vec3, vec4; in particular I'm using a vec3 as my service input but I cannot find a proper widget to put into my mashup which where I can insert the new value and bind it to the service.
Do you know any?
Nov 29, 2016 9:27 PM UTC
Wait, are you taking about OOTB base types?
fmanniti1-VisitorAuthor
Nov 30, 2016 9:31 AM UTC
I don't know if they are OOTB.
I'm talking about this
Nov 30, 2016 10:46 AM UTC
Hi Fabio,
Vec2, Vec3 and Vec4 are meant for Vuforia AR Applications, it are 3D information for visualizing models on Mobile Apps using the Vuforia Mashup Builder. If you are using standard TW Mashups better you don't use it, or if you want to use it you will need to build property service wrappers in order to extract info from the given Vec2,... property as an Infotable.
Best Regards,
Carles.
Nov 30, 2016 10:50 AM UTC
Ok, thanks
