Widget Specific CSS - Tabs
In some way, I want to hide the tab header using CSS. When using CSS, it works properly.
In my single mashup, I have two tab widgets, and the CSS is applied for two tab widgets.
I want apply below CSS with widget specific.
.widget-ptcstabset::part(tabs-header){
 display: none;
How to apply CSS without affecting more than one tab widget?
Note: Thingworx 9.1
PEHOWEAnswer
@Sathishkumar_C,
you need to know the ID of the tabset you want the CSS to affect. In my test case I had a tabset with an ID of "ptcstabset-9" and ptcstabset-16"
Using your CSS from above I created:
#root_ptcstabset-9.widget-ptcstabset::part(tabs-header){
   display: none;
The "#" character followed by the ID of the element identifies the specific element. I have placed my sample below.
   display: none;
Hope that helps.
Peter
PEHOWE17-PeridotAnswer
@Sathishkumar_C,
   display: none;
   display: none;
Hope that helps.
Peter
Thanks @PEHOWE Its working great.
