Aug 7, 2024 7:59 PM UTC
Widget Validation not Working
 I am trying to use the validation inputs for a text box widget. If I manually set these parameters then it works as intended and looks like this:
But if I try to bind validation functions to these parameters for when the text box has a comma, then it simply doesn't work. I have already verified that my service is working correctly and is bound to the properties correctly, but for some reason it just doesn't work when I bind it over on validation. Any ideas?
VladimirNAnswer
Aug 8, 2024 8:52 AM UTC
Please specify which version of the software you are using.
VladimirN24-Ruby IVAnswer
Aug 8, 2024 12:13 PM UTC
9.3.13
