Wildcard in SQL query with input param
I need to make a SQL query in Thingworx. The query should read (if I were creating it directly):
SELECT * FROM MyDB.MyTable where Name like '%Name_Input%'
Another PTC forum post had recommended this as a possible solution:
SELECT * FROM MyDB.MyTable where Name like '%' || [[Name_Input]] || '%'
But this query (above) does not work. The post was from the year 2014 and I'm currently using 8.4.1, so I'm guessing that's the issue.....
Solutions anyone?
20-Turquoise
This could have been changed due to the changed security policies. I will verify and get back to you/this thread with an update.
20-Turquoise
This was part of security updates, works to spec.
ague1-VisitorAuthor
So, when you say, 'works to spec', are you saying that this SQL query should in fact work?
11-Garnet
I had the same issue, here's what I found to work, this works in 9.4.1:
SELECT * FROM MyDB.MyTable where field_values LIKE '%'+[[source]]+'%'
