Will ThingWorx Flow support high available clusters ?
ThingWorx foundation has HA and active-active supporting ,  does someone knows when  Thingwork Flow will support HA as well ?  My  customer want to know it .
Sean
If the question is about Flow working with ThingWorx HA cluster, that is supported and tested. But if your query is about flow itself in a HA that is not supported and tested. About support in future, I need to check with the PM.
seanccc17-PeridotAuthor
@mnarang ,
My question is about the Flow itself in a HA ,  please help to check with PM about the roadmap to support it .  Thank you .
Sean
Luckily there was already an internal discussion going on this topic. And the response is - it is there in the roadmap but no timeline/release is set for this. You can open a support case and then provide all details which can be forwarded to PM to priorities this.
