Oct 12, 2022 8:58 AM UTC
Wrapped java.lang.NullPointerException
Below is my code:
//creating an infotable
let Log = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "DataShape"
//Defining date variable
var currentDate;
//assigning valueList variable to my infoTable property that contains values (current it only has one row)
var valuesList = Things["TestThing1"].infoTableThingProperty;
//loop through the infotable above
for(var i=0; i<valuesList.length; i++){
// new object
newEntry = {
duration:valuesList[i].duration,
source: valuesList[i].Source,
Type: valuesList[i].Type,
StartTime: valuesList[i].StartTime,
EndTime: valuesList[i].faultEndTime,
Voltage: valuesList[i].Voltage,
Text: valuesList[i].Text
//adding my object values to the infotable
Log.AddRow(newEntry);
//adding my infotable to the stream
var newLog = Things["SinkWorx.PwrSupplyError_Stream"].AddStreamEntries({
values: Log /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = Log;
I keep getting the error above, I am not sure why.
Does anyone know how I can fix it?
Kind Regards,
TB
Oct 12, 2022 12:50 PM UTC
duration: valuesList[i].duration,
Any o these INTEGER/NUMBER values might by NULL.
Try only with STRING values and change accordingly
Oct 12, 2022 9:31 AM UTC
try this..
let streamEntryData = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
	dataShapeName: "StreamEntryWithValues"
var currentDate;
for (var i = 0; i < valuesList.length; i++) {
	// new object
	newEntry = {
 // StreamEntryWithValues entry object
 let streamEntry = {
 sourceType: undefined,// STRING
 values: Log,// INFOTABLE
 source: undefined,// STRING
 tags: undefined,// TAGS
 timestamp: new Date()// DATETIME
	streamEntryData.AddRow(newEntry);
	values: streamEntryData /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = streamEntryData;
Janicen16-PearlAuthor
Oct 12, 2022 12:39 PM UTC
Hi @Sathishkumar_C  thank you for the suggestion but I am still getting the same error.
