WriteCSVFile
I have 100 rows in CSV File. I want to replace only one row. This snippet: Resources["CSVParserFunctions"].WriteCSVFile(params2); is not accepting one row as an input. Iam getting an error "JavaException: java.lang.Exception: Unable To Convert From com.thingworx.types.collections.ValueCollection to INFOTABLE ".
1. How to update only one row of csv file?
2. Shall i pass arrays tothe input data?
 var params2 = {
path: filePath2 /* STRING */,
data: rowCSV /* INFOTABLE */,
fileRepository: "SystemRepository" /* THINGNAME */,
withHeader: true /* BOOLEAN */
};Resources["CSVParserFunctions"].WriteCSVFile(params2);
slangleyAnswer
Support
Hi @AP_9587236.
You will need to load the whole file into a ThingWorx infotable, Is it a correct assumption that you would want to make the updates via a mashup?  If so, you would need to tie the infotable to a grid, make the change, and then write it back out to the CSV file.
If you can provide a better understanding of your application, we might be able to provide a more efficient way of handling it.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @AP_9587236.
--Sharon
Support
Hi @AP_9587236.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
