Oct 10, 2024 1:47 PM UTC
WriteCSVFile API withHeader: true changed The order of columns in generated CSV File
While using the Resources["CSVParserFunctions"].WriteCSVFile API withHeader: true, The order of columns are changed in generated CSV File. How to maintain the same order of columns in CSV File.
Resources["CSVParserFunctions"].WriteCSVFile({
path: "/"+formattedDate+"/"+FolderName+"/"+FileName /* STRING */,
data: ExportData /* INFOTABLE */,
fileRepository: "WCCompareXA_Repository" /* THINGNAME */,
withHeader: true/* BOOLEAN */
Rocko
RockoAnswer
Oct 10, 2024 3:11 PM UTC
The order should be determined by the ordinal of the column which you can set:
table.dataShape.fields["A"].ordinal = 3;
table.dataShape.fields["B"].ordinal = 2;
table.dataShape.fields["C"].ordinal = 1;
Check https://www.ptc.com/en/support/article/CS388066
Rocko
Rocko19-TanzaniteAnswer
