Writing data to AWS from Thingworx
Hi, I am trying to send some calculated data from the Thingworx platform to AWS. What will be the recommended approach for this?
slangleyAnswer
Support
Hi @sabhz.
Are you trying to write to an external database?  If so, as long as it supports JDBC, you can set up a database connection in ThingWorx.  Refer to this page in the Help Center for more information.
If this isn't helpful, please provide more information regarding your external system.
--Sharon
Can the following article help? Article - "ThingWorx JDBC connection to Amazon Web Services (AWS) Redshift database": https://www.ptc.com/en/support/article/CS293064
sabharees15-MoonstoneAuthor
Thanks for your response, but we cannot move further with Redshift 🙂
If we use redshift now, we need to mirror our data in the data lake. I trying to find a reliable solution to connect with AWS IoT core.
slangleyCommunity ManagerAnswer
Support
Hi @sabhz.
--Sharon
