7-Bedrock
Xaxis labels are only showing for every other column - label chart
Hello Everyone,
I'm facing an issue with the label chart during runtime. Xaxis labels are showing alternatively when the mashup is viewed in chrome (100-67% Zoom), with zoom less or equal 50 all labels are showing.
Has anyone faced this issue before? How can I show all the labels even with 100% zoom on all screens?
Please share your valuable inputs.
Thanks in advance,
Bhavya P C
7-Bedrock
Hi @BP_10197309,
Please advise the ThingWorx version you are running so we can try to recreate it here.
Will it be possible for you to provide the mashup and entities?
-kpankar
7-Bedrock
Hi @kparhad ,
Thanks for your response. I'm using Thingworx 9.3.5-b1258 version.
As it is client project I'm not be able to share the same mashup but I can replicate mashup and share it with you
Bhavya P C
Hello @BP_10197309 ,
Could you pls try the following:
1. try diagnosing using Chrome developer tool and share the screenshot.
2. Use another browser like Firefox and check if the issue is still present.
Bhawna
you can set the "NumberOfXLabels" Widget-Property to the desired number.
Afterwards, regardless of the zoom, the same number of values should always be displayed.
Best regards
Marc
7-Bedrock
Hi Marc,
Thanks for the response
I'm using label chart widget and we don't have "NumberOfXLabels" Widget-Property.
Bhavya P C
There seems to be no function for your case in the Label Chart.
So I recommend switching to the bar chart with the ChartType "Column Chart" (or "Pareto Chart Widget (Themable)") and possibly some configuration effort to keep the style.
Best regards
Marc
