XAxisField issue on "ROC Chart" widget
I'm using ROC Chard widget
it works fine, linking an infotable to "Data" and selecting the XAxisField and DataField 1..2....
However the XAsixField can be parametrized.
If i link XAsixField to a string (eg a textbox, just to try) giving the name of the field to use, the widget does not works.
I can make it running only if a select directly on the widget the infotable field use.
Has anyone used this XAsixField as a parameter ?
Is there a particular "syntax" for selecting the field name with XAsixField ?
Just to be sure are you referring to the Chart widget from the Marketplace?
iguerra16-PearlAuthor
probably it was installed by thingworx analytics (Analytics Builder)
I didn't take from marketplace.
This seems to be the only widget allowing a Line X-Y  chart and possibility to dynamically customize the axis fields.
could you please share a screenshot from ThingWorx Composer --> Import/Export --> Extensions --> Manage
