XY coordinates on chart on mouse click
Hi, Is there any way we can find out x-y coordinates on mouse click on any image or on any chart and also  Can we do it with custom widget, If so then how we can create custom widget for this scenario
Support
Hi @HC_9989186
Coordinates should display by hovering on the chart.  Not clear on the use case regarding images, so if you can provide more details, we'll be happy to try to answer your questions.
You should be able to write a custom widget for any needed functionality, but if you are not an experienced developer, I would recommend reaching out to our Sales team.  They can help to engage a consultant for writing the extension for you.
--Sharon
Support
Hi @HC_9989186
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
