Y- axis values on label chart getting repeated values
hi,
   I am getting repeated values on Y-axis on label chart like 0,0,1,1 if i set to interval 4 and set to auto scale when there is no data present. See the below image for reference.Please provide the solution for this as soon as possible.
Thanks in advance,
Sheetal Sable
Hi @Sheetal_sable,
If auto-scale is enabled, the graph behaves as you posted. Disable auto scale and set the interval 0 to 4 which will set the graph scale as 0 to 4 irrespective of the input values.
With regards
Yedukrishnan
Hi @Sheetal_sable,
With regards
Yedukrishnan
