Zip file using rest services
I need a custom services to hit external API which provides ZIP File (contains pdfs files) as response and display those pdf files in mashup.
@PaiChung
22-Sapphire I
I've never done this, but there is a LoadBinary service in the contentloader functions, you can try that and then save that to the filerepository as zip, and then use the unzip command on the filerepository
after that do a getfilelisting to display the link in a webframe widget.
@PaiChung
i tried LoadBinary service in the contentloader functions and saved the response as zip file. But zip file not saved properly. i suspect issue in receiving binary response.
Can you share sample code to receive zip file as binary response?
Vijay
22-Sapphire I
Sorry I do not have any code example.
