My application for the 30 day Evaluation of Chalk was not approved
Last week I applied for the 30 day Evaluation of Chalk. However, the application has been rejected. I would like to be approved by you, what should I do?
I already use a personal edition, is it affected?
TetsuAnswer
This problem was solved by having PTC Japan cooperate.
The cause is as follows.
Fallon, Duffy <dfallon@ptc.com> wrote  2018/09/18 :
I just heard back from the team on our side –  it looks like the rejection happened because as a partner, you needed to include a (P) in front of the business name.  I just want to confirm that you’re seeking to sign up for a partner account and I can go ahead and get everything setup.
@Tetsu Could you please share the login ID been used to signup for Chalk ? We can check internally to get feedback on the request status.
-Durgesh
Tetsu1-VisitorAuthor
Thank you for your reply.
login ID : takahashi.tetsuto@canon-its.co.jp
Please check it.
Hi @Tetsu and @dupatel -- apologies for the delayed response, I had intended on responding yesterday.
Let me check-in on this as I'm curious why you were not approved and also get you setup for an evaluation.
I'll cc: you on an email that I'll be sending out shortly.
