Provide extra time to re join a hosted session
A great enhancement request for multiple customers with limited connectivity could be to enable extra time to reconnect to a hosted session disconnected by network problems without the need of creating a new session code again
tmccombieAnswer
Thank you for your feedback!
Can you provide some additional information around this issue you've seen? Connect codes are valid for 8 hours unless the host closes the session. Non-host users should be able to use the same session code to join again if they are disconnected due to a network issue.
tmccombie21-Topaz IAnswer
