Feb 24, 2021 10:39 AM UTC
2D and 3D image code
Hello All,
I have been programming a step by step instruction, and noticed these issues when showing images:
This works fine with 2D images:
$scope.view.wdg["image-1"]['imgsrc'] = 'app/resources/Uploaded/1. Checkliste Werkzeug.png';
Note that the file name has spaces and dots.
This will not work for 3D images:
$scope.view.wdg["3DImage-1"]['src'] = 'app/resources/Uploaded/1. Checkliste Werkzeug.png';
But this works:
$scope.view.wdg["3DImage-1"]['src'] = 'app/resources/Uploaded/1_Checkliste_Werkzeug.png';
Why do the spaces and dots work in the 2D image file names but not for the 3D?
Also I've noticed that SVG files do not work for 3D images on my Apple Iphone and Ipad devices.
Best wishes,
Alex
Feb 24, 2021 4:21 PM UTC
Hi @AlexK ,
probably for the src property  the setter will not encode the url.
You can try to use the encodeURL javascript method
Example:
$scope.test=function(){
//sample file name = '1 2 4 bla. bal .jpg'
//this url for the file name should be encoded
 $scope.setWidgetProp('image-1','imgsrc', 'app/resources/Uploaded/1 2 4 bla. bal .jpg' );
//for for 2d without encoding
 $scope.setWidgetProp('3DImage-1','src', encodeURI('app/resources/Uploaded/1 2 4 bla. bal .jpg') );
 $scope.$applyAsync()
for the 3DImage widget you need to convert the url using encodeURL .
For the 2d Image widget  you do not need to encode the url but anyway it will work both:
//and
 $scope.setWidgetProp('image-1','imgsrc', encodeURI('app/resources/Uploaded/1 2 4 bla. bal .jpg') );
Hi @AlexK ,
Example:
//and
AlexK15-MoonstoneAuthor
Feb 25, 2021 11:36 AM UTC
Thanks! It worked!
