Jul 4, 2017 11:11 AM UTC
2D Label and Value Display widgets support State-based formatting using ThingWorx State and Style definitions
Wanted to know how we can achieve Value Display widgets support State-based formatting using ThingWorx State and Style definitions in Thingworx Studio.
If there is any documents/links shared in this regards would be really helpful.
Avinash
katteAnswer
Jul 5, 2017 3:55 PM UTC
Avinash Gangaiah​ The Style definition feature is partly related to ThingWorx entities and depends on work from Thingworx. The steps to add style definitions are:
  • Add 'Data Grid' widget in Studio, bind the widget with the desired ThingWorx data (infotable) and Select the data columns to be visible
  • Create a style definition in ThingWorx platform.
  • In ThingWorx Studio, click on Data Grid widget's 'State Definition' (edit) button that will show a list of style definitions in the dialogue box
  • Select the desired 'Style Definition'
Let me know if that doesn't work.
-Giri
katte5-Regular MemberAnswer
-Giri
Mar 5, 2018 5:28 AM UTC
For 2D State definition will work only at the time of page load not at run-time.
But for 3D state definition is not working
