Jan 25, 2021 7:12 AM UTC
3D IMAGE are not visible after publishing
Vuforia Studio
When you design a 3D experience I find that one is unable to do the below:
1. 3D IMAGE - these do not behave consistently after the experience has been published - when you view the experience the images are not visible even if the visible property is enables
2. When you toggle the visibility property via JavaScript or Binding this also behaves inconsistently - images are not toggled accordingly
Jan 25, 2021 8:42 AM UTC
  • Do you a simple example Project who shows this problem, please ?
Best regards,
Samuel
MaF1-VisitorAuthor
Jan 26, 2021 10:25 AM UTC
Please find attachment.
Jan 28, 2021 6:59 AM UTC
I can't see 3D images with Hololens 1 either.
May 17, 2021 11:43 PM UTC
Do we have solution for this? I am having the same problem too.
Adrian
May 20, 2021 7:29 PM UTC
Hi @unknown_G
Could you please provide the device details (OS, Name , model) that you are using to view the experience. Also, please share the vuforia view app version and view log file to track the issue.
May 20, 2021 11:17 PM UTC
Hi Ytella,
Good day.
I am making a content for 3D Eyewear.
So I am using Hololens 2.
My studio version is 9.0.4.4996 and the view in my Hololens was up to date.
To make things simple, I created a new Experience with just 1 JPEG File in it.
When i click Preview, I can see the image I put in the middle of the experience.
But when I use my Hololens 2, even just projecting the Image without any JS. bindings or whatsoever, I can't see it.
Adrian
