Jan 17, 2018 7:25 AM UTC
3D Label rotation along with model
Hello
I am trying to rotate a 3d label along with model .
I have mated the label on the 3d model and used a slider widget to rotate model in y direction, but when i rotate only the model rotates the label remain at the same coordinate position. Is is possible to make the label move along with model. Help me to solve.
7-Bedrock
Jan 17, 2018 11:41 AM UTC
What I have done to solve that is make the ThingMark rotate instead then everything rotates relative to that when you view the experience. It isnt 100% ideal but does the job for simple rotation and scaling.
Jan 17, 2018 5:20 PM UTC
Why don't you bind the slider to both: model and 3dlabel?
The mate tool is just for positioning - it's not "sticky" afterwards.
