Using an app parameter and some JavaScript you can achieve this.
Step 1: Depending on which axis you want to rotate the model on, create a new app parameter and bind it to the corresponding rotation property of your model.
I created an app parameter 'ry' and bound it to the y rotation property
Step 2: Add a JS function for the rotation to Home.js
I used the below function - the quadcopter example experience has some additional code examples for moving model parts.
var timerId = -1;
var angleIncrement = 45; // degrees
var timingInterval = 30; // milliseconds
$scope.rotateModel = function(){
if (timerId > -1) {
clearInterval(timerId);
timerId = setInterval(function() {
if (!$scope.app.params.ry) {
$scope.app.params.ry = 0;
$scope.$apply(function(){
$scope.app.params.ry += angleIncrement % 360;
}, timingInterval);
Step 3: Create a button and call the JS function on the Click event
The model will now rotate around the y axis after clicking on the button.
