Apr 8, 2019 3:57 AM UTC
A way to change a tablet experience to a 2D eyewear experience without starting from scratch
Hi!!
I would like to ask, currently is there any way for me to to change a tablet experience to a 2D eye-wear experience without starting from scratch?
Any help or reply would be greatly appreciated.
Thanks!!!
sdidierAnswer
Apr 8, 2019 7:38 AM UTC
Sadly this behavior doesn't exist in the last release.
The only way that I found is to start a new Project from scratch.
Copy and paste between source and original Projects ressource files.
Open some .json files in a text editor and copy some part of them for supported Widgets in 2D eyeswear.
It is needed to be very carreful with this method because a bad syntax in .json file can create some bugs in Vuforia Studio.
So, I don"t recommand to use it at all!
The best is to open 2 Projects, to compare them and to copy Javascript code and recreate bindings and Widgets.
Best regards,
Samuel
sdidier17-PeridotAnswer
Best regards,
Samuel
