Feb 14, 2017 9:42 AM UTC
Animation is getting lost after saving the project
Hi everyone,
I'm creating expériences using pvz and pvi files to generate animations. No issue during the creation process. I can declare the pvz model and pvi sequence without any issue but as soon as i save the project, the reference to the sequence is getting lost and i cannot select it in the scolldown menu anymore. I have to remove the model and recreate it from scratch, then bind again my toggle buttons actions on the model.
Any help is greatly appreciated,
ankiguptaAnswer
Feb 20, 2017 1:19 PM UTC
Hi Michel,
Could you please remove the uploaded .pvi files and then choose the Sequence URL from the dropdown. The associated .pvi files shows in the dropdown without uploading it in resources. It seems that some name conflict occurs on adding the same .pvi files manually.
I hope it help.
Ankit Gupta
Feb 15, 2017 9:21 AM UTC
Michel Sorette​,
Could you please confirm the Studio version you are on.
Do you see the .pvz file in the Resources in the left pane. Does the .pvz file gets removed from the resources too after save?
Try adding the file to resources first then press save and then try to use it in your project.
Feb 15, 2017 10:11 AM UTC
Hi
I noticed this comportment in the previous version but it still occur in 1.9
Yes, the pvz file is still available in the ressources after the save (all pvz are still there btw - std, low, med, high). So are the pvi files.
always load them first then use them.
To make sure, i just tried again  : i loaded all the ressources first, then saved, then used them, then saved again.
Again, the pvi disapear from the sequence url entry field and it's not available anymore to be selected.
If i publish it straight after finishing the setup, in 1.9, the published experience can play the sequence but the pvi file has disapeared from the entry field.
Feb 16, 2017 10:22 AM UTC
Hi Michel,
are the files something you can share (privately)?
There's a chance it's resource related and I'd like trying to reproduce this on my environment.
You can send me a private message here as well to exchange details.
Cheers
/Michael
