Dec 9, 2017 12:13 AM UTC
Animations in hololens aren't equal to the preview
Animations pvi included in pvz (created with creo illustrate 3) saw in hololens aren't equal to the preview or the mobile version. Why? For example: when I rotate a object composed by various parts, in preview the rotation is correct but when I see it in hololens, each part isn't syncronized.
Jan 26, 2018 9:00 AM UTC
I have seen the same behavior,
For example, if you create a movement in illustrate you can set a rotation axis, and rotate warts around that axis.
In the Hololens this moves each part to the new location.
Did not find a reason why.
Jan 26, 2018 11:23 AM UTC
Hololens is still on the old renderer and thus doesnt support all the functionalies and movements.
Take into account Hololens = Creo Illustrate <=4.0 only.
https://help.thingworx.io/studio
Jan 26, 2018 11:28 AM UTC
I used Creo Illustrate 3
