9-Granite
Dec 28, 2021 6:55 AM UTC
Area Target Generator - Possibility to combine many area target files
I'm using Area Target Generator to generate area target. But the limitation is 5 minutes only.
The area that I want to scan is quite wide, and need more time to scan the whole area.
My question, is it possible to combine many area target files into one file? Because in Vuforia Studio, can upload only one area target file.
Thanks.
9-Granite
Dec 28, 2021 8:40 AM UTC
Thank you for the doc.
To my understanding, it is possible to compose many area target files in unity but is there any other way to combine all these area target files into one file only so that I can use Vuforia Studio since Vuforia Studio can upload only one area target file?
Thanks.
Jan 3, 2022 8:27 AM UTC
as far as I know, it is not possible to combine the area targets in  a single file for studio.
However you can have multiple views with different area targets and switch the to the right area target once you reach a certain location for example.
