Feb 23, 2021 4:16 AM UTC
Automatically hide popup after 2 seconds
I have 2 popups in 2D view. I want the first popup to be shown after step 1 finished playing, and then the popup will be hidden automatically after 2 seconds. Then, the second popup appear after first popup hidden.
How can I do this?
18-Opal
Feb 23, 2021 3:23 PM UTC
You can use $scope.$on() to listen for the end of a step, check that it's the right step, and then do your popup handling. An example might look something like this:
// typed off the cuff, debugging is left as an exercise for the reader..
$scope.$on('stepcompleted', ()=> {
 // make sure it's the right step
 if ($scope.getWidgetProp('model-1','currentStep')==1) {
 // show the first popup immediately
 $scope.app.fn.triggerWidgetService('popup-1', 'showpopup');
 // use timeouts to close first popup and open second one
 $timeout(()=>{ $scope.app.fn.triggerWidgetService('popup-1','hidepopup')}, 2000);
 $timeout(()=>{ $scope.app.fn.triggerWidgetService('popup-2','showpopup')}, 2000);
 // if you want to hide the second popup after some delay, add another timeout
 // here, where the timeout value is the desired time for popup-2 plus 2000 for the
 // first timeout
