Apr 13, 2018 9:16 AM UTC
Bug ThingWorx Studio 8.2.2 animate Popup
In the latest version of ThingWorx Studio 8.2.2 the css for PopUp no longer works.
in the previous one I used the following CSS to animate the Popup window, after the update the show / Hide animation does not work anymore.
CSS Used
.twx-popup-container {
transition: -webkit-transform .5s cubic-bezier(.455,.03,.515,.955);
transition: transform .5s cubic-bezier(.455,.03,.515,.955);
transition: transform .5s cubic-bezier(.455,.03,.515,.955),-webkit-transform .5s cubic-bezier(.455,.03,.515,.955);
-webkit-transform: translateX(0) translateZ(0);
transform: translateY(0px) translateZ(0);
.twx-popup-container.hidden {
display: block !important;
-webkit-transform: translateX(250px) translateZ(0);
transform: translateY(-600px) translateZ(0);
Has something changed ?
Giuseppe
May 4, 2018 8:00 AM UTC
I asked development and he suggested to use instead the angular ng-hide.
So I tested your css now in the modified version and it does animate. I am not sure if this is the correct/ desired apperance. Could you test it,  please, and let me know!
Here the modified version:
.twx-popup-container.ng-hide {
Apr 16, 2018 7:39 PM UTC
Hi Giuseppe,
Are you using the PopUp widget or $ionicPopup? Are you receiving any errors after upgrading?
Apr 17, 2018 7:37 AM UTC
i used the PopUp widget .
Apr 23, 2018 9:56 AM UTC
News for this Problem ? 😞
Apr 30, 2018 5:01 PM UTC
in generally it seems that popup widget is working with  style .
For example the following style:
.test1{
width: 40%;
border: 5px solid red;
-webkit-transition: width .35s ease-in-out;
transition: -webkit-transform .8s cubic-bezier(.455,.03,.515,.955);
.test1:hover{
width: 90%;
border: 8px solid yellow;
adding to Applicaiton and then set the popup class property will work as expected:
So means  that the style definition is working fine for this style in this  case.
I tried to use the your style definition  in chrome as general style but it was not working.
When I tried to use your style it moves the element on the top but I did not see any otters effects. What should it do?
How did you generate the mention style and in which version  was it working?
May 2, 2018 8:14 AM UTC
The problem is that up to the previous version, that style I wrote, scrolled the
popup animating it ( ver. 8.2.1 Thingworx Studio) ,in the last versione ( 8.2.2)  the effect of the animation no longer exists,
but appears as if it were a simple hide / visible, without animation.
May 4, 2018 9:15 AM UTC
using ng-hide and no longer hidden works great, thanks 1000
Giuseppe
