18-Opal
Oct 3, 2019 3:36 PM UTC
Bug with 3DImage visibility on iOS
I've discovered what seems to be an iOS-specific bug. Here's the scenario:
I have a 3DImage (a warning icon) that needs to flash in the experience. I accomplish this using a $timeout that toggles the "visible" property on the widget, something like this:
$scope.blinkStatus = true;
$scope.blink = function() {
 $scope.blinkStatus = !$scope.blinkStatus;
 $scope.setWidgetProp("3DImage-1","visible", $scope.blinkStatus);
 $timeout($scope.blink, 500);
This works just as it should on the preview and on Android. But on iOS, if you let the blinking continue for any length of time (about a minute or so), it crashes Vuforia View completely.
It only seems to happen with 3DImage widgets. I'm able to flash a normal 2D image widget in the same way without the app crashing.
Is this a known issue? I'm going to investigate workarounds, maybe using opacity. In the meantime, I'll attach a simple project file that demonstrates the problem.
sdidierAnswer
Oct 4, 2019 12:41 PM UTC
Hello Clay,
I have checked the example Project.
I am able to have the crash in Android Vuforia View also as in in Ipad!
In Vuforia View log files, I didn't an error related to this crash.
I am reporting that to R&D as a bug.
More details in this article :
https://www.ptc.com/en/support/article?n=CS314554
Best regards,
Samuel
18-Opal
Oct 3, 2019 3:38 PM UTC
Sample project.
18-Opal
Oct 3, 2019 3:39 PM UTC
Also, FWIW, this also seems to happen if I use $interval instead of $timeout
18-Opal
Oct 3, 2019 4:20 PM UTC
It seems to work to use "opacity" instead of "visible" to control flashing, i.e. I can cycle opacity between 0 and 1 to achieve a flashing effect without causing the app to crash.
sdidier17-PeridotAnswer
Hello Clay,
Best regards,
Samuel
18-Opal
Oct 4, 2019 3:47 PM UTC
Thanks @sdidier !
