Nov 19, 2019 12:05 PM UTC
call experience with code javascript
Is there a way through scripts to call an experience from within another experience
thnx
Nov 19, 2019 2:17 PM UTC
I found the Solution. 🙂
if someone needs the solution here.
$scope.load=function() {
window.location='..URL of Experience'
the url of experience ,  use that in Experience Sharing.
BYE
Giuseppe_Fiore15-MoonstoneAuthorAnswer
BYE
Nov 19, 2019 2:31 PM UTC
also this will work. You need to check on the different devices - but think to remember that on one device the location was not working / but not sure -
$scope.openUrl=function()
let url= "https://www.bing.com/"
// here instead of this link used the deep link which is provided by experience share menu of the project
window.open(url)
As url  here use  for the url / variable value -  the deep link which is provided by the menu Share>Share Experience > copy  of the project which you want to open.
Addional your device need to be configured to associate the link with the Vuforia View
