Oct 9, 2018 10:55 AM UTC
Call function based on visability of an image
I'd like to call the function below base on the visibility of an image but i am unaware of how to do this. Could someone help please?
$scope.intro = function() {
	var labelText = $scope.view.wdg['checkstart'].text;
	var spokenText = labelText.substr(labelText.indexOf(" ") + 1);
	$scope.app.speech.synthesizeSpeech({ 'text': spokenText });
18-Opal
Oct 9, 2018 9:40 PM UTC
It depends on what you mean by "visability".
If you mean "when the visability parameter is set to true", then yes, you can do that using $scope.$watch, something like this:
$scope.$watch('view.wdg["image-1"].visible', function (val) {
 if (val) {
 $scope.intro();
However, if you mean "when the user moves their device around so the image enters their field of view", then I think the answer is no. I don't think there's a way to detect whether an object is in the viewport or not. (I would be happy to be proven wrong, if there is a way to do this!) I also don't know of a way to get the location of the camera relative to the 3D view origin, so you can't try to derive it that way.
18-Opal
 if (val) {
 $scope.intro();
