Aug 20, 2019 1:25 PM UTC
call function from external JS-lib
Hi.
Currently I'm trying to call a function from an external JS-lib. (tooltip.js)
I managed to load the JS-File via
twx.app.fn.loadResourceScript('Uploaded/tooltip.js');
as mentioned here
https://community.ptc.com/t5/Vuforia-Studio/Including-js-file-from-resources/m-p/556781#M3480
But unfortunately I'm getting an  ReferenceError: Tooltip is not defined.
My function in home.js looks like this:
//Tooltips
$scope.createTooltips = function(){
 var referenceElement = document.querySelectorAll('[widget-id="photoBtn"]');
 const instance = new Tooltip(referenceElement, {
 title: "Hey there",
 trigger: "click",
 instance.show();
the function(variable) I want to use from external js (tooltip.js) looks like this.
var Tooltip = function () {
 function Tooltip(reference, options) {
 ...some code....
Someone has an idea?
feilAnswer
Aug 20, 2019 2:47 PM UTC
My mistake.
I just saw that I load the JS-files after the model was initialised.
That's to late.
Now it's working.
Thanks!
Aug 20, 2019 2:27 PM UTC
Hello feil Marble,
  • Where or when do you load the library with Javascript code ?
  • In Preview, in Developer toolbar, in Sources tab, do you see the javascript file related to tooltip.js loaded
Best regards,
Samuel
feil1-VisitorAuthorAnswer
My mistake.
That's to late.
Now it's working.
Thanks!
