Mar 24, 2022 3:29 AM UTC
Can I create PDFs dynamically?
When using Vuforia Studio as an AR manual, I want to export the implementation record as a report.
I prefer PDF as the report format. Can i export Vuforia Studio values?
I understand that this is possible by working with thingworx, but I want to output a simple report.
Best regards,
Apr 15, 2022 11:21 AM UTC
@Y.Moto , I overlooked the "tool like insight" in your post. So , in this case I need to correct my statement:
OK if you want to implement similar functionality for tracking of Vuroria Studio experiences like insight  - I think the best options is to use Thingworx services - so you will have your data then in Thingworx and is better to create there the reports.
To create any reports in studio could be also easy done via javascript , In this case so you can generate e.g. a json object containing a "snapshot" of  all settings of the current Studio Project  attributes or parameters in the Vuforia View session  and send then this json file to a server . Then the server could handle the generation of the report file from the received json object.
I do not think that generation of a report directly on the mobile device will be feasible
Mar 24, 2022 4:22 AM UTC
yes it is possible
Y.Moto1-VisitorAuthor
Mar 31, 2022 7:56 AM UTC
Thank you for the reply.Do you have any sample code for me? I tried to implement it using libraries such as jsPDF, but gave up because the libraries did not use to be available...
Apr 14, 2022 11:50 AM UTC
Hi @Y.Moto ,
I see that @Suraj_Patil  wrote that this is possible but unfortunately there is no more info about how is this possible /at least here in the topic
My question is what is the goal here . Do you want to print to pdf  the status of the augmentation display /screen hardcopy / so to share it e.g. via e-mail or is the idea here  different - e.g. to create on server side some reports. In this case you can use via the External data section in Studio some TWX service to forward the task to Thingworx.
