May 10, 2017 10:41 AM UTC
Can I use Repeater widget in ThingWorx Studio to create gauges dynamically?
Hi, I want to use the repeater widget in ThingWorx Studio to generate gauges dynamically.
In the "Data" field I bind an InfoTable and I want to create as many gauges as infotable rows.
Is it possible?
Alessio
May 10, 2017 2:48 PM UTC
Hi Alessio,
it should be possible, the repeater will repeat its inner element, e.g. a gauge and fill it with the data it gets from the ThingWorx service (InfoTable).
Are you running into any specific issues?
Cheers,
Michael
atenti1-VisitorAuthor
May 11, 2017 1:09 PM UTC
Thanks for your reply.
I tried to do that with my infotable, but i have a problem.
First of all, i would like to use this infotable in this example to explain my problem :
CountryCapital
ItalyRome
FranceParis
So, I want to create 2 gauges with the "Capital" value. How can I do that?
I tried to bound "All items" in the field "Data" of the repeater and then I bound the "Capital" field (from the "Current Selected Item" menu) into the field "Value" of the gauge I put as inner element of the repeater.
I see 2 gauges, but with the same values, and if I click on the value, it changes with the next value (for example: I see "Rome" in both. if I click on "Rome", I see "Paris" in both).
How can I do that?
Thanks in advance,
Alessio
Jun 19, 2018 2:41 PM UTC
Alessio.
Not sure, if this is still open for you, but for the other user's sake, I will give a response:
Please refer to the Helpcenter and to this article and follow exact the steps explained there:
  • First bind the 'All Items' from your service to the Repeater Widget
  • THEN place other widgets ON the Repeater! E.g. a Panel and some Value Displays.
  • This will enable the  'Repeater Data Item' properties on the 'External Data' panel. Select the desired properties from there and bind them to the Widgets in the Repeater - not from "Current Selected Item' list! Otherwise you will end up in a situation like you have described.
