Apr 8, 2025 4:57 AM UTC
Can Image target or Multiimage target can replace model target approach
Can Image target or Multiimage target can replace model target approach for assembly instructions by overlaying 3d model on physical model
Apr 10, 2025 9:02 AM UTC
Hi @thrinath,
is that a question or statment - a question I believe so some kind ow  to use an image Target for 3D models? But could you clarify ? Please, provide more details about the application case and the goal? Thanks
So my understanding there is that   you want to use an image target (instead of modelTarget) to scan a real 3D model (where you try to scan an imageTarget which displays a view of the 3D physical model? That is what I will understand from the description. Thanks!
