Can not mirror from HoloLens
Created an experience on HoloLens and it works but does not mirror to a monitor during use.
Any suggestions on why the Experience does not Mirror?
It should be able to be done, I created an app that I published to the HoloLens using Visual Studio and it works and mirrors to a monitor during use.
You must say enable "Hey View, enable recording" in order for augmentations to be mirrored. Theres documentation in the recording section of the following link: https://help.vuforia.io/studio/#page/ThingWorx_Studio_Help_Center%2FEyewearBestPractices.html%23wwID0E41PO
wrsamuels14-AlexandriteAuthor
Super, cant wait to test that.
Weak i didn't find it myself, thanks for the aid.
should be able to test and reply in the am.
Still could not get it to Mirror. The publishing is mobile item or eyewear specific it seems, is there a specific mirror app?
William Samuels​ Correct way to mirror/streaming your HoloLens view:
  • Select the 'ThingWorx View' app from the HoloLens homescreen
  • Wait till the Green logo gets displayed, scan the ThingMark
  • Once the 3D model gets loaded, say the command "Hey View, Enable Recording"
  • Now back in the desktop, mirror/stream from your Mixed Reality capture.
Let me know if that works.
