Jul 20, 2017 2:43 PM UTC
Can't validate or publish - authentification fails
I installed Thingworx version 8.0.1 (8.0.1.1646) trial a couple of weeks ago and have created and saved a test experience however I can't find a way to publish it.
I'm an existing PTC user and have confirmed I'm using the correct username and password (I am successfully logged into my Thingworx Developer Portal account through the Thingworx webpage using the same login details) and I can successfully 'save' the experience to the web, however when I try to 'validate' the experience service or publish it and enter my login details in the "Authentification Required" dialog box it repeatedly fails authentification.
The log error is:
"error: [twx-studio:basic] Failed to authenticate experience server https://3e1hmks2.pp.vuforia.io [my PTC username] 401"
All proxy details in settings are blank.
Please help!
James
YuxiuAnswer
Jul 25, 2017 1:58 PM UTC
James,
I have reset your password. Please check your email account for the new password.
Thanks.
Yuxiu
Jul 20, 2017 4:43 PM UTC
Hi James, Did you use the same credentials to auto-configure your instance?
jhruby1-VisitorAuthor
Jul 21, 2017 7:08 AM UTC
Hi Tara,
I don't remember an auto-configuration but yes I'm entering my PTC credentials into the username/password authentification dialog box when it pops up after clicking validate or publish.
James
Jul 24, 2017 11:27 AM UTC
Hi Tara,
Should I be entering my PTC credentials? If not please can you confirm which credentials I should be logging in with please?
James
