Oct 24, 2019 11:58 AM UTC
Can we create a project with Voice command for Realwear HMT-1 device using the Vuforia Studio?
Can any one suggest me the possibilities to add voice command to RealWear HMT-1 device using Vuforia Studio? If yes, is there any user manuals to create the project using the voice command?
Please suggest
18-Opal
Oct 24, 2019 4:30 PM UTC
There's a lot of voice command recognition built in when you publish a project for Realwear. Any button will be automatically configured to be "speakable" based on the text label. So, for example, if you have a button in your UI that says "Next", the use wearing the headset can just say "Next" to trigger the button press.
If you need more than that, you can use Javascript to insert "data-wml-speech-command" attributes onto UI elements to make them available for activation using voice commands. You can see some examples of the required markup here: https://www.realwear.com/knowledge-center/developer/environments/html-env/html-api/
