Apr 6, 2020 9:18 AM UTC
Can we move any widget such as 3D image in 3D space by holding it in Hololens 2?
Apr 8, 2020 1:37 PM UTC
In the current functionality the direct answer is NO- or  it is not possible yet. But as mention in the last post you can use the mention workaround to fix an element on the gase vector and then to move it when you move your device and set the object in particular distance in front of you - as mention in the post and demonstrated in the demo project
Apr 6, 2020 1:22 PM UTC
Hi @vivekse ,
I think the approach which is described in the article "How can we make a 3D Widget on HoloLens visible in front of me every time ? " could be possible helpful. There e.g. we have a curser (3DImage widget) which is moving with you gaze vector and have. With some additional work we can implement e.g . to start move the object, holding it with the gaze vector - means the object is fixed on the gaze vector of front of your device with particular distance.
