Feb 9, 2017 5:53 AM UTC
Can we update a cell color of a grid on basis of its value
I have my data in data table and i am displaying that in grid in mashup.
Can i update particular cell color on basis of its value.
for example,
if cell contains value 'ON' than that cell should be displayed with green color.
And if cell contains value 'OFF' than that cell should be displayed with red color.
kborkarAnswer
Feb 10, 2017 1:15 PM UTC
Just done it with version 7
In state formatting selected statusstate and then given my parameters
Thank you all for replies...
Feb 9, 2017 11:52 AM UTC
Hi Kedar Borkar​, Yes That's possible.
Just click on the drop down icon on the top left of the Grid.
Then configure the Column containing ON OFF details.
Go to Column Renderer & State Formatting Tab and select State-based Formatting
Set the dependent field as your column.
Set the State Definition. You might have to create one if you haven't already that defines the state and color.
I Hope it helps.
Feb 9, 2017 11:53 AM UTC
Check following link for more details on State Definition: PTC
Feb 10, 2017 10:06 AM UTC
Hello Kedar, which version of Thingworx are you working on?
kborkar1-VisitorAuthorAnswer
