May 24, 2017 3:26 AM UTC
Cannot publish my project --Uploading project (0.1 MB of 3.3 MB completed)
Cannot publish my project --Uploading project (0.1 MB of 3.3 MB completed):I tried two projects .  All stopped when Uploading project (0.1 MB of.......).  see:error.jpg
the log:log.jpg
Who can help me ? Thanks!
May 24, 2017 2:46 PM UTC
Are you able to access your experience service through a browser? I noticed that you have 2 different experience services listed. Can you confirm which one is correct? You can confirm this by using the Portal Login option under the 3 dot menu on the upper right hand side within Studio.
tozhang1-VisitorAuthor
May 25, 2017 1:15 AM UTC
I think it is the first one, "https://cdhyslii.pp.vuforia.io/", I got it when I registered in  the ThingWorx® Studio Trial. I do not know why I can not publish.
May 26, 2017 8:41 AM UTC
did you enter the good user/password?
Jun 1, 2017 7:38 AM UTC
Anyone?
It failed when I followed the sample!
The same error.
Jun 1, 2017 2:39 PM UTC
Hej Tong,
thingmarks have no influence on that -> your given thingmarks are all empty because nothing has been uploaded to it.
Could you please reset your "access" attribute in the info panel to not being public?
Jun 1, 2017 2:51 PM UTC
Tong An Zhang​ I see a "403 -forbidden" error in your initial log file. From the fact that you were able to login to ThingWorx Platform, validate the Experience Service URL, I anticipate that this might be something with your permissions and more specifically write permissions to the Experience Service. That might be the reason why you were able to validate but couldn't publish (i.e., write permissions)
Because you were able to access ThingWorx platform, can you please check if your username is under 'Administrators/Developers' group?
Mar 2, 2018 9:14 AM UTC
Can you elaborate where I can find the Administrators/Developers group in Composer?
Br,
Antti
