Cannot select Sequence URL
Hi
I am new at using Studio and learning by using remote control exercise. I have a problem in that I cannot see pvi file when I clock sequence URL drop-down. Here' what i am doing -
Under Resources, I select + and added pvi file. I see pvi loaded under 'resources'.
On the right panel under 'Model Details' I use drop down 'Sequence URL' and do not see pvi file as is being suggested in the demo exercise.
Please guide me as to what I am incorrectly.
Thank you for help.
ankiguptaAnswer
Hi Abbas Bagasra​,
I hope you have already added .pvz file. Generally .pvz file already consist of .pvi file. Could you please remove the uploaded .pvi files and then choose the Sequence URL from the dropdown. The associated .pvi files shows in the dropdown without uploading it in resources. It seems that some name conflict occurs on adding the same .pvi files manually.
ankigupta5-Regular MemberAnswer
Hi Abbas Bagasra​,
abagasra1-VisitorAuthor
Anik
Thanks for responding. Yes I added both pvz and pvi file and can see in the Resource.
Sorry for asking dumb question but how do i remove .pvi file from the resource?
Thanks again.
To clarify, under Resource list i dont see option to select and remove.
