Cant publish to ES after 8.4.5.4404 update
I cant seem to publish to my experience server after the 8.4.5.4404 update
@Rmcrabb  Could you please confirm if you are facing an issue with all types of project publish like ThingMarks, Spatial & Model Target. There has been an issue reported to R&D with Model target so want to know if ThingMark & Spatial target is working or not.
Also, share the complete Studio logs to review.
-Durgesh
Rmcrabb1-VisitorAuthor
The problem only happens with model targets. If I delete the model target I can publish.
@Rmcrabb  Thank you for confirming and as advised for Model Target there is a known issue which has been reported internally & fixed under JIRA DT-23570. We are expecting the fix to be released in next release.
Possible workarounds on Windows-
  • reverting to previous version
  • setting serverMTG=false in builder-settings
-Durgesh
