May 27, 2020 10:58 PM UTC
Change CSS class of a button
I'm trying to create a function which removes the class of a button and then adds another class:
$scope.tutorialShow = function () {
 angular.element(document.querySelector("[widget-id=instructionInfoButton] button")).removeClass("test").addClass("button");
I'm not sure the error in my code.
WilsonTAnswer
May 28, 2020 12:51 AM UTC
Hi Micah,
Can you try the following?
 $scope.setWidgetProp('instructionInfoButton','class',undefined);
 $scope.setWidgetProp('instructionInfoButton','class','button');
WilsonT14-AlexandriteAnswer
Hi Micah,
May 28, 2020 4:59 PM UTC
I believe the quotes around the widget id are not correct in your code.  Here is an example from an experience I've created:
angular.element(document.querySelector('[widget-id="PartIDListGrid"] .row:nth-child(2)')).addClass("SelectedItem");
I think yours should be (I didn't test):
angular.element(document.querySelector('[widget-id="instructionInfoButton"] button')).removeClass("test").addClass("button");
